2000 Volvo S40, ECM/Inputs/Outputs Scan Data
Operation of VVT solenoid signal as seen by VIDA when engine is started cold. At first, ECU sends a "tap, tap, tap" ground signal to VVT solenoid to sense if things are ok (beginning high rise in pic) and then more/longer ground signal is sent to operate the V...
| Engine | 1.9 L / 4 cyl / GAS |
2000 Volvo S40 1.9L
