1992 Audi 100, CKP Sensor, CMP Sensor, Ignition - Primary Waveform
here the blue curser is in the position of tdc for #3 cylinder , engine is set up so tdc of 3 is base setting for t belt , cranking no start , note timing to 3-5 coil is very advanced ,,,, backfireing thru air box ... intermitently timing is correct for the 1s...
| Engine | 2.8 L / 6 cyl / GAS |
| Component | , , |
1992 Audi 100 CS 2.8L
| Component | , , |
