2006 Ford Escape Limited, Engine/Propulsion Waveform
Relative compression, starter amps, firing order is 1,4,2,5,3,6 and the low compression cylinders are in the rear bank, firewall side, cylinders 1,2,3
2006 Ford Escape Limited 3.0L
