2006 Ford Escape Limited, Engine/Propulsion Waveform
CH C is starter amps, low compression cylinders are 1,2,3, CH D is the WPS500 is on the dipstick tube and the high crankcase pressures line up under the cylinders with low compression
2006 Ford Escape Limited 3.0L
