2006 Ford Escape Limited, Engine/Propulsion Waveform
CH A is the cranking injector 2 from 50ms up to 181ms, CH C is the starter amps and it shows every other cylinder has lower compression. The firewall side has the low compression cylinders 1, 2, 3 and the front cylinders 4, 5, 6 has the good cranking compressi...
2006 Ford Escape Limited 3.0L
