2006 Ford Escape Limited, Engine/Propulsion Waveform
CH B is a pressure transducer on the dipstick tube showing compression pressure pulses leaking by some of the cylinder's piston rings, into the crankcase, CH C is the starter amps, CH D is a pressure transducer in cylinder 2, the cylinder compression measures ...
2006 Ford Escape Limited 3.0L
