2007 Chevrolet Suburban 1500 LS, Engine/Propulsion Waveform
The green CH C is a WPS500 in cylinder 7 cranking, the intake lifter is collapsed and the intake valve is not opening. Cranking compression is 16 psi and the cylinder vacuum measures -13.7 psi or 27.5 inches of vacuum, cranking. The tan CH D is the starter amp...
| Engine | 5.3 L / 8 cyl / FLEX |
2007 Chevrolet Suburban 1500 LS 5.3L
