2017 Ford F-250 Super Duty Platinum, ECM/Inputs/Outputs Waveform
This is a waveform of a 6.7 Powerstroke that is setting a P0016 code. because the gear on the crank slipped 1 tooth. This gear is just pressed on the crank with no keyway for alignment.
| Engine | 6.7 L / 8 cyl / DIESEL |
2017 Ford F-250 Super Duty Platinum 6.7L
