2005 Saab 9-3 Linear, ECM/Inputs/Outputs Waveform
After replacement of throttle body assembly for a P2135 DTC, found waveform as pictured on the TPS2 signal wire (Pin 4). Signal has no missing low-pull points, WOT (high voltage) points reach above 4.5V.
2005 Saab 9-3 Linear 2.0L
