2008 Mitsubishi Eclipse SE, ECM/Inputs/Outputs Waveform
CMP CKP after correcting timing belt. Cylinder 2 compression waveform. Cylinder 2 is front hole on front bank. Some waveforms on iATN have inverted signals. Not sure if that affects performance or start-ability.
2008 Mitsubishi Eclipse SE 3.8L
