1985 Nissan 300ZX, Fuel Supply Waveform
Posted to the Waveform Library on 12/19/2019
CH C injector 2 volts near the ecm when i tapped the control wire to ground, but I should have chosen the 50v or 100v scale to measure the injector turn off voltage. CH D all 6 injectors draw 10 amps when the control wire is tapped to ground.
1985 Nissan 300ZX 3.0L
Engine3.0 L / 6 cyl / GAS
Trans4-speed AutomaticTransmission
SubsystemFuel Supply
ConditionKnown Good
ConditionKnown Good
