2011 Ford Escape Limited, BATT/Charging/Starting Waveform
Battery drain, CH A batt volts, CH B amp clamp on batt cable shows repeating 6.1A spikes until I pulled the rear wiper fuses
| Engine | 3.0 L / 6 cyl / FLEX |
2011 Ford Escape Limited 3.0L
