2002 Hyundai Sonata, ECM/Inputs/Outputs Waveform
Posted to the Waveform Library on 11/25/2019
This vehicle came in for stalling and a P0335 code. This capture is of the CKP (yellow trace) and CMP (green trace) while idling around 700rpm. The CKP sensor ended up being faulty, but this capture can be used to check CKP/CMP timing/relationship (timing good...
2002 Hyundai Sonata 2.4L
Engine2.4 L / 4 cyl / GAS
ConditionKnown Good
ConditionKnown Good
