2003 Dodge Caravan SE, Engine/Propulsion Waveform
Posted to the Waveform Library on 11/11/2019
CH A WPS in cyl 4 with good cranking compression pressures, then the compression suddenly drops down to 89 psi. The compression/power stroke tower is leaning and the vacuum pocket at the bottom of the expansion stroke measures 16.8"Hg. The cmp, ckp are in sync
2003 Dodge Caravan SE 3.3L
Engine3.3 L / 6 cyl / FLEX
SubsystemEngine/Propulsion
Component,
Component,
