2010 Toyota Prius, ABS/Inputs/Outputs Waveform
Posted to the Waveform Library on 11/10/2019
Connected to hazard/flasher input circuit at SKU. Shows signal from malfunctioning SKU when hazard switch is turned on and back off. When on, signal drops to 0v/ground.
2010 Toyota Prius 1.8L
Engine1.8 L / 4 cyl / ELECTRIC/GAS
Trans0-speed AutomaticTransaxle (Electronic)
SubsystemABS/Inputs/Outputs
ComponentOther
ComponentOther
