2012 Chevrolet Equinox LTZ, BATT/Charging/Starting Waveform
Known good AC ripple waveform. Total amplitude is ~71mV as indicated on the Delta measurement using the cursors. Usually anything 200mV or above is considered excessive. This capture was obtained while load testing the battery KOER with a 130A load tester, to ...
| Engine | 2.4 L / 4 cyl / FLEX |
2012 Chevrolet Equinox LTZ 2.4L
