2013 Hyundai Elantra GL, ECM/Inputs/Outputs Waveform
Green Trace: Intake camshaft. Rising edge located halfway between 4 and 5 teeth before missing tooth on crankshaft. Yellow trace: Crankshaft, at idle, probe in red wire only which is why waveform is not even across the zero mark.
2013 Hyundai Elantra GL 1.8L
