2013 Hyundai Elantra GL, ECM/Inputs/Outputs Waveform
Posted to the Waveform Library on 10/2/2019
Green trace: Exhaust camshaft waveform. Rising edge located approximately at the rising edge of 17 teeth past the CKP missing tooth. Yellow Trace: Crankshaft at idle, probe in red wire only, which is why the trace is not even across the zero mark.
2013 Hyundai Elantra GL 1.8L
Engine1.8 L / 4 cyl / GAS
Trans6-speed StandardTransaxle
ConditionKnown Good
ConditionKnown Good
