2007 BMW 335xi, Ignition Waveform
Green trace is current ramp of #1 ignition coil at idle. Yellow trace is voltage waveform at idle. Note: I do believe that I had a slightly-off intake cam phaser/VANOS actuator, which may explain the increasing voltage at the end of the burn line on the voltag...
2007 BMW 335xi 3.0L
