2007 BMW 335xi, ECM/Inputs/Outputs Waveform
I had a problem vehicle that kept setting a fault code for the intake cam performance, and crankshaft/camshaft correlation. Vehicle also misfired under load. This waveform shows intake and CKP sensor signals with the VANOS system disabled. My scope is only two...
2007 BMW 335xi 3.0L
