2010 Ford F-150 STX, ECM/Inputs/Outputs Waveform
CH A is CAN H, CH B is CAN L, intermittent no start, int. U codes, banging on the under hood fuse box, problem was a bad solder joint on the cluster circuit board
| Engine | 4.6 L / 8 cyl / GAS |
2010 Ford F-150 STX 4.6L
