2002 Ford F-350 Super Duty Lariat, ECM/Inputs/Outputs Waveform
This truck loses ICP under load. It will fall to 1200 psi under load. It flags code P1211. It appears that the PCM is not pulling the IPR yellow control wire all the way to ground. This was captured KOEO. I'm thinking that the PCM is shot.
| Engine | 7.3 L / 8 cyl / DIESEL |
| Condition | Unknown |
2002 Ford F-350 Super Duty Lariat 7.3L
