1994 Ford E-250 Econoline XL, Transmission Waveform
This is the EPC Solenoide. EPC was not in component list... Bad (top) and good EPC solenoid driver in PCM... This was causing multiple driveability problems with no codes... Note the driver bouncing off of ground at a very high rate... This bounce would show u...
| Engine | 4.9 L / 6 cyl / GAS |
| Subsystem | Transmission |
1994 Ford E-250 Econoline XL 4.9L
