2008 Dodge Nitro SE, Fuel Supply Waveform
Good voltage to the injector, the PCM is holding the injector winding to ground for 3.6ms, when the PCM stops grounding the winding, the kick back voltage measures 70.5v and there is a closing pintle hump
| Engine | 3.7 L / 6 cyl / GAS |
| Subsystem | Fuel Supply |
2008 Dodge Nitro SE 3.7L
