2007 Toyota Camry CE, BATT/Charging/Starting Waveform
All accessories on at 2,200 rpm, CH A is the scope leads across the batt terminals AC ripple voltage x10, CH B scope lead on the alt output post, AC ripple voltage, CH C is the alt output in amps, the scope is sampling at a high Sample Rate
| Engine | 2.4 L / 4 cyl / GAS |
2007 Toyota Camry CE 2.4L
