2010 Ford E-450 Super Duty, Engine/Propulsion Waveform
#2 rod bearing failure knocks at TDC under normal conditions, knocks at transition from power BDC to Exhaust stroke when the cylinder pressure is lowered by cancelling the injector
| Engine | 6.8 L / 10 cyl / GAS |
| Component |
2010 Ford E-450 Super Duty 6.8L
| Component |
