2010 Ford E-450 Super Duty, Engine/Propulsion Waveform
#2 rod bearing failure, #2 ignition trigger, gm knock sensor with magnet on oil pan cancel injector, has knock at TDC, then much higher amplitude knock at BDC with the lower cylinder pressure
| Engine | 6.8 L / 10 cyl / GAS |
| Component |
2010 Ford E-450 Super Duty 6.8L
| Component |
