1993 Honda Accord DX, Engine/Propulsion Photo
This is a bleeder screw from a failed clutch slave which I cut the end off of.I then added the nut(common 8X 1.25)and an old a/c o-ring such that it would create a positive seal at the slave when screwed in in place of the bleeder. I use it attached to a Mityv...
1993 Honda Accord DX 2.2L
