2014 Hyundai Elantra Coupe GL, ECM/Inputs/Outputs Waveform
CH B is the VVT solenoid voltage PWM by the PCM, in CH C, I connected a jumper wire to the VVT solenoid control wire and I am tapping the control wire to ground. The amp clamp is on the jumper wire and you can see the amperage required to pull the solenoid's p...
2014 Hyundai Elantra Coupe GL 2.0L
