2012 Dodge Grand Caravan Canada Value Package, Transmission Waveform
Vehicle moved in reverse, P075A, p0882, CH A is the feed wire to sol pack, CH B is the trans control relay pin 86 grounded by the TCM, then there is an open to the TCM, CH C is the feed to the trans relay coil pin 85, CH D sol pack amps
| Engine | 3.6 L / 6 cyl / FLEX |
| Subsystem | Transmission |
2012 Dodge Grand Caravan Canada Value Package 3.6L
