2012 Dodge Grand Caravan Canada Value Package, Transmission Waveform
Vehicle moved in reverse, CH A power feed wire to sol pack drops to zero volts, CH B trans control relay pin 86 grounded by the TCM, then ungrounded, CH C feed to trans control relay pin 85, CH D sol pack amps
| Engine | 3.6 L / 6 cyl / FLEX |
| Subsystem | Transmission |
2012 Dodge Grand Caravan Canada Value Package 3.6L
