2009 Honda CR-V EX, ABS/Inputs/Outputs Photo
code 64 for steering angle sensor power supply problem. found voltage bleeding over onto pin 5 at sas and pin 33 at vsa. This is a pic of connector c405, this is where the wires for pins 2,3 and 4 at the steering angle sensor are junction together. Found melte...
| Engine | 2.4 L / 4 cyl / GAS |
2009 Honda CR-V EX 2.4L
