2008 Toyota 4Runner Limited, ABS/Inputs/Outputs Photo
Rear wheel bearing hub that was no longer triggering the wheel speed sensor. The trigger wheel/tone ring is built in to the wheel bearing.
| Engine | 4.0 L / 6 cyl / GAS |
2008 Toyota 4Runner Limited 4.0L
