1991 GMC C1500 Sierra, Fuel Supply Waveform
Posted to the Waveform Library on 12/30/2018
Engine cranking, no start, CH A injector power, zoomed in x20, CH B MAP signal wire, zoomed in x7, CH C coil wire with low kv and no burn times because cylinders, piston rings and new plugs are fuel fouled, CH D one injector amps on time of 87ms, open CTS
1991 GMC C1500 Sierra 5.0L
Engine5.0 L / 8 cyl / GAS
Trans4-speed AutomaticTransmission (Electronic)
SubsystemFuel Supply
Component,
Component,
