2004 Nissan Altima, ECM/Inputs/Outputs Waveform
RED is all coil amperage Blue is coil #1 trigger from PCM Yellow is coil voltage Green is coil ground vehicle will not start, this is the end of a long crank. As the key is let off, a boom is heard in the exhaust. A late firing?
| Engine | 2.5 L / 4 cyl / GAS |
2004 Nissan Altima 2.5L
