2007 Nissan Frontier SE, Emissions Scan Data
Tank will hold vacuum if vacuum added manually. Here, the Vent hose is pinched off, (because Purge was commanded on 100% in running purge test, the engine killed and switched to vent test which can not be done with engine running. The pinch was then let off wi...
| Engine | 4.0 L / 6 cyl / GAS |
| Subsystem | Emissions |
2007 Nissan Frontier SE 4.0L
