2004 Chrysler Pacifica, Engine/Propulsion Document
A running cylinder waveform analysis via our Fluke PV350 to determine if the crank flex plate tone wheel was the culprit or if the timing belt system was awry.
Login to view this file Auto Repair Pros: Join iATN to view this file and others Vehicle Owners: Find a nearby iATN member to repair your vehicle Anthony from New York
| Engine | 3.5 L / 6 cyl / GAS |
2004 Chrysler Pacifica 3.5L
