1996 Toyota Camry LE, ECM/Inputs/Outputs Waveform
Posted to the Waveform Library on 2/5/2014
1996 Toyota Camry 3.0 V6 -- White is coil current, pink is primary trigger for that coil, yellow is an inductive pickup around the ignition cable, and blue is a capacitance pickup around the ignition cable. This capture shows a normal ignition event.
1996 Toyota Camry LE 3.0L
Engine3.0 L / 6 cyl / GAS
Component,
ConditionKnown Good
Component,
ConditionKnown Good
