2000 Volkswagen Jetta GLS, Engine/Propulsion Waveform
2000 VW Jetta 2.0L AEG -- Channel 1 is crankshaft position sensor, channel 2 is camshaft position sensor, channel 3 is a WPS 500 in cylinder #1, and channel 4 is a capacitance pickup around ignition cable #1 which was grounded through a spark tester. This engine was idling normally during this capture, although the accessory drive belt was not installed.
Login to view this file Auto Repair Pros: Join iATN to view this file and others Vehicle Owners: Find a nearby iATN member to repair your vehicle Shannon from California |
2000 Volkswagen Jetta GLS 2.0L
