2000 Volkswagen Jetta GLS, Engine/Propulsion Waveform
2000 VW Jetta 2.0L AEG -- Channel 1 is crankshaft position sensor, channel 2 is camshaft position sensor, channel 3 is a WPS 500 in cylinder #1, channel 4 is a capacitance pickup around ignition cable #1 which was grounded through a spark tester, and channel 6 is a voltage drop between battery negative and ground -- a relative compression waveform. The fuel pump was disabled and this engine was cranking.
Login to view this file Auto Repair Pros: Join iATN to view this file and others Vehicle Owners: Find a nearby iATN member to repair your vehicle Shannon from California |
Engine | 2.0 L / 4 cyl / GAS |
Subsystem | Engine/Propulsion |
Component | , |
Condition | Known Good |
2000 Volkswagen Jetta GLS 2.0L
Component | , |
