2000 Volkswagen Jetta GLS, Engine/Propulsion Waveform
2000 VW Jetta 2.0L AEG -- Channel 1 is crankshaft position sensor, channel 2 is camshaft position sensor, channel 3 is a WPS 500 in cylinder #1, channel 4 is a capacitance pickup around ignition cable #1 which was grounded through a spark tester, and channel 5 is a Firstlook Sensor hooked to the brake booster line nipple on the intake manifold. This engine is out of time mechanically and would not start.
Login to view this file Auto Repair Pros: Join iATN to view this file and others Vehicle Owners: Find a nearby iATN member to repair your vehicle Shannon from California |
Engine | 2.0 L / 4 cyl / GAS |
Subsystem | Engine/Propulsion |
Component | , |
Condition | Known Bad |
2000 Volkswagen Jetta GLS 2.0L
Component | , |
