2005 Ford Taurus SE, Ignition Waveform
2005 Ford Taurus 3.0L V6 VIN 2 -- Yellow is a capacitance pickup on ignition cable for cylinder #3, green is a low amp probe around the common coil power feed. Power kv is displayed. Ignition cable has 20kv gap spark tester at end with no spark jumping.
Login to view this file Auto Repair Pros: Join iATN to view this file and others Vehicle Owners: Find a nearby iATN member to repair your vehicle Shannon from California |
| Engine | 3.0 L / 6 cyl / FLEX |
2005 Ford Taurus SE 3.0L
