1999 Audi A4 Quattro, Ignition Waveform
1999 Audo A4 Quattro AEB 1.8T -- Yellow is PCM to ICM for cylinder #4, and green is a low amp clamp around the common ground wire at the ICM. Engine is running with an obvious misfire. Firing order is 1342.
Vehicle Data1999 Audi A4 Quattro 1.8L
Engine | 1.8 L / 4 cyl / GAS |
Trans | 5-speed StandardTransaxle |
Subsystem | Ignition |
Component | , |
Condition | Known Bad |
