2000 Ford Contour SE, Fuel Supply Waveform
Using three scopes measured power, ground, fuel pump power, fuel pump ground, fuel pump current, inputs/outputs at pump driver module (FPDM) and fuel pressure using a Vantage pressure transducer.
Vehicle Data2000 Ford Contour SE 2.0L
VIN | 3FAFP6638Y |
Engine | 2.0 L / 4 cyl / GAS |
Subsystem | Fuel Supply |
Component | |
Condition | Known Bad |
