2003 Toyota Highlander, Photo
Here is a view of a broken wire. This makes the job more difficult since you will need to carefully unsolder and remove the wires. Use a solder removing wick or solder removing tool to remove the wires from the circuit board. No drilling or surface soldering allowed.
Login to view this file Auto Repair Pros: Join iATN to view this file and others Vehicle Owners: Find a nearby iATN member to repair your vehicle Eric from Wisconsin |
Vehicle Data2003 Toyota Highlander 2.4L
VIN | JTEGD21A13 |
Engine | 2.4 L / 4 cyl / GAS |
Subsystem | Not Applicable |
Component | Other |
