1995 Geo Metro, Engine/Propulsion Waveform
1995 Geo Metro 1.0L 3 CYL - Yellow is a capacitive pickup on the coil wire, red is an inductive pickup around cylinder #1 ignition cable, green is a Firstlook Sensor in the exhaust, and blue is a pressure transducer in the #3 cylinder. The camshaft position is marked in purple. #3 ignition cable was grounded with a spark tester. This capture was taken cranking with the fuel injector disconnected. Firing order is 1-3-2. The transducer translation is (((v-.5)/4)*314.7)-14.7).
Login to view this file Auto Repair Pros: Join iATN to view this file and others Vehicle Owners: Find a nearby iATN member to repair your vehicle Shannon from California |
Vehicle Data1995 Geo Metro 1.0L
1995 Geo Metro 1.0L
Engine | 1.0 L / 3 cyl / GAS |
Trans | 5-speed StandardTransaxle |
Subsystem | Engine/Propulsion |
Component | , |
Condition | Known Bad |
