2006 Ford Focus ZX4, Engine/Propulsion Waveform
2006 Ford Focus ZX4 2.0L VIN N - Cranking compression test with throttle blade open for cylinder #1. Yellow is crankshaft position sensor signal, green is a pressure transducer in cylinder #1, and blue is camshaft position sensor signal. Engine has 112k on t...
Vehicle Data2006 Ford Focus ZX4 2.0L
Engine | 2.0 L / 4 cyl / GAS |
Subsystem | Engine/Propulsion |
Component | , |
Condition | Known Good |
