2001 Toyota Camry LE, ECM/Inputs/Outputs Scan Data
Checking a Maf sensor. Above 3000 RPM short term and rpm will no longer mirror each other. This test is best performed on a test drive below 3000 RPM with light throttle tip in monitoring the Short term and RPM for a mirroring pattern.This vehicle had a bad Maf.
Login to view this file Auto Repair Pros: Join iATN to view this file and others Vehicle Owners: Find a nearby iATN member to repair your vehicle Kevin from Manitoba |
Engine | 2.2 L / 4 cyl / GAS |
Component | |
Condition | Known Bad |
2001 Toyota Camry LE 2.2L
Component | |
