2001 Toyota Camry LE, ECM/Inputs/Outputs Scan Data
Checking a Maf sensor. Notice how short term and RPM mirror each other. This test is best done under light throttle tip in, under 3000 RPM. Bad Mass air flow sensor.
Login to view this file Auto Repair Pros: Join iATN to view this file and others Vehicle Owners: Find a nearby iATN member to repair your vehicle Kevin from Manitoba |
Engine | 2.2 L / 4 cyl / GAS |
Component | |
Condition | Known Bad |
2001 Toyota Camry LE 2.2L
Component | |
