2005 Ford E-450 Super Duty, ECM/Inputs/Outputs Waveform
Open Coil voltage & current from a misfiring fuel injector. Positive lead was on Coil positive and Negative lead was on Coil (-), both leads were backprobing the FICM connector. Notice the rapid increase in coil current. This coil passed the resistance test (0.6 ohms) but was still causing excessive current flow.
Login to view this file Auto Repair Pros: Join iATN to view this file and others Vehicle Owners: Find a nearby iATN member to repair your vehicle Robby from Alabama |
| Engine | 6.0 L / 8 cyl / DIESEL |
2005 Ford E-450 Super Duty 6.0L
